RE: Aileron Alignment
If you draw a line from the leading edge to the trailing edge, then the ailerons shoulld be on this line. Call it evenly spaced between top and bottom. In no case should they be lower. Above the line a small amount is OK. This would probably place then in line with the bottom surface.
