RCU Forums - View Single Post - Big problem! Interference Galore
Old 09-19-2004 | 01:22 PM
Michael Basson's Avatar
Michael Basson
Default Big problem! Interference Galore
Hi there all
i have finally got the guts to go fly my edge 540T. first gasser so i am a bit scared of the maiden flight.
i did a range test. at 40 paces the plane started glitching. the one half of the plane moves faster than the other half. the slow half looks like it almost doesnt move smooth but almost in steps.
2nd range test and at 4 paces the radio was dead.[:@][:@][:@]
3rd time it went up to 30 paces then did the same weird movements.
now my ignition battery, ignition and flight packs are pretty close together. my flight packs i had to put in the front of plane above the landing gear to sort out the CG problem. could this be to close to ignition?
also my 3 switches are right on top of each other. ignition on top then 2 switches on the bottem of that. my aerials are on the bottom of the plane.
crystals have been swoped and i have changed everything i could.
the floating bellcranck has one servo mounted higher than the other. the 2 receivers lie on each side under the highest mounted servo.
receivers are very far from ignition.
any advise should i change something???
please help i am scared of this plane now and i want to sort it out before i fly it.
any help will be appreciated
Michael
