RCU Forums - View Single Post - Just got this started up today need help
Old 09-19-2004 | 10:17 PM
Rob Douglas
Default RE: Just got this started up today need help
To get the engine to shut off. Adjust the idle with the trim tab in the middle. So when you bring the trim tab to the bottom, it will close the carb and kill the engine. The throttle hold switch is set so when you switch it on, the engine goes to idle. For practicing autos. I don't know what radio you are useing but in most you have to set the switch to be active or off.
