RCU Forums - View Single Post - Big problem! Interference Galore
Old 09-20-2004 | 05:49 AM
Michael Basson's Avatar
Michael Basson
Default RE: Big problem! Interference Galore
i check one receiver at a time.
but as i recall even with the motor off it was not good. i will check it again today!! as for everything in the plane it is all brand spanking new. i heard now today even a servo can give problems with range and so on. is this true? this is my first large plane so i do not know what to expect. i am very scared of this bird now. what if this glitch happens in the air? disaster comes to mind very quickly.[&o]
i will check everthing and use all the advise. will let you know if i find the problem.
as for now those receivers are the first to be checked.
OT why is my plane so tail heavy with a DA 50 in? my battery packs are now mounted above the landing gear. as far forward as possible.
thanks for all the advise so far.
much appreciated
Michael
South Africa
P.S. What can i expect of the plane with the first take-off besides pure thrill.
