RE: *Inverted Engine Problem*
You would also do well to put a hot glow plug in it, such as an O.S. F or an Enya No. 3. A hot plug will burn a slightly richer mixture, which is sometimes hard to avoid throughout the throttle range on an inverted engine. In any case, both high and low-end mixture should be tuned.
