RE: Shocky wing position problem?
I just finished gluing my Extra 330A together last night and had the same issue. I Glued the wing 15mm as instructed and cut the notch in 5mm so the fuse lines up in front. The only Issue I can forsee is the CG might be off. I plan on addressing CG when it comes time to mount the battery however. I should have taken a picture obviously since others had the same question I did! Next person that gets in that situation take a screen shot of the missalignment.
