tipover on landings
Hi,
I have a mountain models minflash which flies real nice. The problem I'm having is flying off of grass. No problem in launching, just every time I land the plane noses over due to the high grass and small wheels(I bent the GWS gear shaft). I was thinking of removing the landing gear but the prop (11"/10") would strike the ground first (?). I know with glow you just adjust prop it against the compression. What the heck do you do with electric in these situations ? Any suggestions would be appreciated.
