ORIGINAL: Frost_
stronger or Longer?
Either way it should bolt right up but you may have to cut down the crankshaft to get your clutch setup....
I had one on the old style tub GT that I used to run. The Trinity mount is much stronger and helps to prevent chassis flex therefore keeping the spur from getting stripped when casing a hard jump. Not to mention it will help disipate the heat from the motor a bit better. You might try ubid or ebay. I find a lot of stuff on these two sites.
