motor mount
TX
ORIGINAL: Frost_
stronger or Longer?
Either way it should bolt right up but you may have to cut down the crankshaft to get your clutch setup....
stronger or Longer?
I had one on the old style tub GT that I used to run. The Trinity mount is much stronger and helps to prevent chassis flex therefore keeping the spur from getting stripped when casing a hard jump. Not to mention it will help disipate the heat from the motor a bit better. You might try ubid or ebay. I find a lot of stuff on these two sites.
TX
Sorry Casey.... I sold that GT a couple years back BUT I know the local hobby shop owner and he may still have one lying arround the shop or on an old tub chassis GT. You can email him by going to www.jsbodies.com and clicking on the email link. His name is james shanley and also take a look at the paintjobs he does for rc cars. Tell him Jon from Port Arthur sent you. You can also check out hte forums on his site as well. Great people to chat with and talk to. Of course my forum name there is also DaLosiMan
