RE: Rookie's bad behavior info. needed
I think you didn't get replies because there really isn't any bad tendencies. The only I can think of is the hop you will get if the plane isn't slowed down enough on landing.
The P-70 should do fine but will limit the 3-D flight and tumbles. All around it is a great plane, gently to fly and very fun with the thrust vectoring hooked up. You can't go wrong with this plane.
