YS 110FZ, 91FZ, 91AC etc are fine. OS 91 Surpass II w/ pump is also ok.
For engine mount, you won't have much choices.
MK, Dave Brown, WorldModel, Go model mounts should work fine.
When you use MK or Dave Brow, make sure that you use CA to glue the rubber isolators to the mount body. Otherwise, those rubber isolators don't last much at all. I am not sure if MK has different strength isolators (medium, soft, hard etc).
I am using Go-model mount in a Pilot BeatOn 90. It works much better with soft isolators. This mount has two screws holding the isolator to the mount body while the MK and DB mounts have only one. I don't remember if the World Model's mount has one or two screws.
I just can not add picture of the mount to this message.[
] uploaded more than twice, but neither showed up, so added the picture to gallery.
IP
