RCU Forums - View Single Post - Help: Programming 9C for DLG
Old 09-22-2004 | 09:59 PM
Mousson
Default RE: Help: Programming 9C for DLG
Many thanks Krysta,
I use Glider 1 and not Glider 2 because my plane uses flaperons while Glider 2 is for 4 servos wing, without the flaperon mix. I have a 6 channel receiver: right flaperon on ch.1 and left flaperon on ch.6.
Your mix 1: elevator preset working as expected
Your mix 2: right flaperon preset working as expected
Your mix 3: in Glider 1, I do not have FLAP. This is my problem. I tried, Flp1, Flp2, Aux1, Aux2. No reaction from the left flaperon !
Same thing with the 2 linear mixes: the left flaperon is working as expected on Pmix 6, but noway to make the right flaperon with Pmix 7.
I try another combination with Acro. In this case, I have access to the function FLAP in Pmixes and am able to activate BOTH flaperons in an ofset mix. Same thing with airbrake: by using Pmix 5, Master Throtle, Slave Flap, I am able to move the airbrake the way I want. BUT, in this mode, I lost the Start Ofs and Run Ofs which I want to use for controlling the glider.
My question: is there a bug in the Glider 2 mode ? how can I move the Right flaperon with an Ofset Pmix ? (the flaperons are working fine as ailerons).
Thanks for your support
