RCU Forums - View Single Post - Do I need multiple radios?
Old 09-23-2004 | 12:15 PM
Crashem
Default RE: Do I need multiple radios?
I have 5 planes and one radio,Futaba Skyport 6,it really gets exciting when you have to trim each plane every time.
P40luvr,
What you need to do is mechanically trim each of your models for straight and level flight with the trim sliders centered. This way when you switch models you only have to make sure the trims are centered and adjust the engine idle with the throtle trim. I did this for years without a problem. Yes computer radios make running multiple models much eaisier. But it is not impossible or overly difficult to do this on a radio that doesn't have a multiple model memory
