RCU Forums - View Single Post - Do I need multiple radios?
Old 09-23-2004 | 07:34 PM
rccrazedman
My Feedback: (10)
Default RE: Do I need multiple radios?
ok two corrections on my origenal post.
1 the futaba high and low band split is low 11-35 and high 36-60
2 you also can change over your transmitter channel if it is not a module type radio ,in the us, only by sending it in and having a qualified techniction do the work .
also to add to what some other guys were saying about the single radio that is one downfall of having just one transmitter. Plus to add to this what if you actuadently turn your radio on en rute to the fioeld now all of your planes are grounded. Bruckner hobbies has the 7caf transmitter only for $150 plus $20 for the heli version. that way I can get a nice backup radio. by the way this has a 10 model memery. nice radio I was looking at ione also. one thing is with the 7c radio is that you cannot use a duel elevator servo setup unless you use a y harness, because the fact that if you trim the elevator the second servo does not work with the trim. futaba can fix this for you for a price, but if you use the timmer activated from the throttle it will reset your aielrons value to zero meaning you would not have any control in your aielrons.
