RE: How do u put servos in an ARF if it is all covered alreadY?
The hardest part on some is getting the pushrod through the fuselage and out the little slot to the rudder or elevator.
Here's a "tip" though. Get a small piece of tubing, like from a "Nyrod" and insert it through the slots from the back up into the servo compartment, then put the end of the pushrod into the tube and work them both back and out the slot.
Dennis-
