RE: Warning to Ebay shoppers of simulators!
I have both G2 and AFP. I was told that I can use the G2 interface (their Interlink USB interface) which I have managed to get to work, however, it seems that AFP will not recognize the G2 interface unless the other cable (the adapter that came with the software) is plugged into the computer. I have to use an USB to SERIAL adapter which requires software drivers and so on. Then, when I try to make it work, everything seems reversed or on the wrong channels. When going to the configuration menu, I can change the channel assignments and reverse things but the "progress bars" that show throttle, for instance, do not work. Am I doing something wrong or is this normal? If I am doing something wrong, please let me know because I want to make this work on my notebook as well as my desktop.
Thanks.
