RCU Forums - View Single Post - How do u put servos in an ARF if it is all covered alreadY?
Old 09-24-2004 | 11:49 AM
raideron's Avatar
raideron
Default RE: How do u put servos in an ARF if it is all covered alreadY?
Another good tip when installing your servos is after you tap the hole
for your screws, Put a couple of drops of thin CA around the holes to
strengthen the area, let dry then install your servos.. Don't forget to
use fuel tubing over your RC links to insure they stay on.. Another
good one is if your Kit/ARF comes with metal rods for the throttle, Its
better to modify it by cutting it in half and adding nylon/or something
between the two halfs to have some give in case of nose-in's or just
use a cable for the throttle.. It's been known to save some equipment
during training.
