RE: How do u put servos in an ARF if it is all covered alreadY?
Yub'ster, the only problem I had with the Tiger 2 was the dummies drilled the holes in the firewall for the throttle rod and nose gear upside down. I had to drill my own. Also, if you are using the trike gear, the nose gear metal is pretty soft. Mine bent on every landing. I have since replaced it with Dubro gear. Everything on the firewall that mounts I used screws, nuts and lockwashers. I don't trust blind nuts that use wood screws to tighten (mounting the engine mount). These items always
get loose from vibration.
Dave...
