RE: Prop Removal AAAARRRGGGHHHHH
Very thin string or fishing line. See if you can wrap it between the prop washer and prop or between the prop and prop flange. Be sure to pull tightly as you are wrapping it around. Should create enough tension to lock the prop in place again so you can use it while you are loosening the nut.
