ORIGINAL: exeter_acres
Umm...Building my first Plane
The might Kadet LT-40 ARF... really excited...
question.... are there any tricks to get the pushrod z-bend into the servo without breaking anything??
>Take the screw holding the wheel/arm out of the servo and remove the
>wheel/arm. Now put the wheel/arm on the z bend. NOTE: You will in
>all probability have to enlarge the hole in the wheel/arm so the push
>rod wire will fit. Use a drill for this - you will probably need a 1/16",
>5/64" or 3/32" drill bit to get the proper size, depending on the size of
>the pushrod wire.
> At this point turn the transmitter and receiver on so the servo will
>center. Put the wheel/arm back on the servo so the z bend has
>equal movement forward and back when the servo is activated with
>the transmitter. Make any final adjustments to center the control
>surface with the clevis. (screw it in or out as needed to center the
>control surface - make sure you have AT LEAST 4 FULL THREADS
>remaining inside the clevis.)
I'm having a heck of a time
the servo is installed...should I unscrew it, insert the pushrod and then reinstall the servo??
also
I have Futaba S3004 servos... they have a Wheel instead of an arm.....does it matter what hole I put the pushrod in as long as it is even??
>Yes, it does make a difference. To reduce the amount of throw (movement )
>on a control surface move the pushrod wire in toward the center of the
>wheel/arm on the servo (use a hole closer to the screw holding the
>wheel/arm on ) and further out on the control horn attached to the control
>surface (use a hole closer to the end of the horn ). You would do the opposite
>to increase the throw. Be sure you re center the control surface afterwards.
>Some people prefer to use the wheels instead of the arm type. A lot
>will depend on your preference AND the amount of clearance you have
>available. Remember, each arm will center differently on the servo,
>just as each set of holes on a wheel will center differently (i.e. - the
>hole you want to use will be 90 degrees to the servo ) and you can
>always cut off the unused arms if needed for clearance.
Thanks in advance....
Hope this answeres your questions.
