RCU Forums - View Single Post - Tips/Tricks for installing pushrods??
Old 09-27-2004 | 01:48 PM
raideron's Avatar
raideron
Default RE: Tips/Tricks for installing pushrods??
Also keep in mind "Mechanical advantage" of your placement on
control horns.. On the control surface, the closer you move the
control rod towards the surface you "per say" get more travel..
but it also makes it "harder" to move that surface, and with
standard servos, you could end up with less deflection.. This
problem really won't show itself on a trainer.. But something
to keep in mind..
