RE: Need Cut Off Switch Replacement
Zenoah makes some fine pieces of equipment but their cutoff switch is not one of those fine pieces.
Just go down to the nearest Radio Shack and buy a heavy duty toggle switch to replace the Zenoah switch. I use the heavy duty switch simply because it handles vibration better and has a big enough handle on it to easily shut off the ignition quickly when needed. A slide switch is probably more reliable, but not as handy to use.
Building is easy.------ Maintenance is a chore.
