RCU Forums - View Single Post - Its Here!! Double Vision
Old 09-28-2004 | 08:33 PM
  #385
obi1
Default RE: Its Here!! Double Vision
Just received my DV,beautiful, but I have a few questions if ye guys would be so good as to answer ,
on the last page of the instructions (updated online version) it says you can use 2 y-leads for ailerons,it also says this setup will allow a flap option ( ailerons can be dropped ) , can anyone explain to me how this is possible??
Also it recommends lowerring the leading edge of horizontals , but mine seem to be in line with trim ( appeared to be lowerred already) , do I have modded version? or should i still lower by 1/8th as instructions say?
On another note , I would like to use a duralite 6v regulator (with 2-cell 2000mah li-ion), anyone know if its safe to use as I will be using all digitals? unsure of current capability of these regulators ( and receiver also ) as i would like to use 7 digitals , and 2 standards for throttle and choke. would I be overloading regulator/receiver?
Another question , what length extensions for each servo did you guys end up using or each servo?
Thanks for any responses , gotta say it seems a lotta plane for the money!!
I am impressed so far
