RE: BME 110Xtreme?
Hi Guys,
My 110 in the Comp ARF has no excessive vibrations. The only people that are having trouble with too much vibration have the motor mounted on stand-offs. The motor has way too much torque to have it hanging out in the air like that. Mount it solid and you will have no problems.
Tim,
I see you are running the Biela 28/10. How does this prop work for you and what kind of RPM's are you getting? I also talked with Kris about the cans and the only ones that would fit in my Comp ARF are the Pefa L canisters. I broke the engine in with a Mejlick 28/10, and even running it rich the prop made so much noise I couldn't stand it. I have since tried a Mejlick 25/12 3-blade and the Biela 26/10 3-blade. It turns both of them a little over 6,000 and both of them work good for IMAC. They don't work well for 3D, because they won't spool up fast enough. I don't like wooden props because they keep coming loose. Any information you have on propellers would be helpful. I don't want to keep trying these expensive propellers just to try them. Thanks for your help.
Big Bob
