RCU Forums - View Single Post - hmm someting wrong here
Old 09-29-2004 | 11:51 AM
pompebled
Default RE: hmm someting wrong here
Hi Wis,
The boat runs like a submerged drive on 7 cells should, speedwise.
Your motor may have a sticker on it saying 700, but judging by the size of the cells, it's a 600 at best.
You need the caps to keep interference low.
The second pic of the boat's interior holds the answer to your troubles; it's a mess, cable wise!
Keep all powerlines short and away from the antenna, receiver and servo/esc leads, as far apart as possible, I suspected as much from the video; when the boat gets further away from your transmitter, the interference from powerlines takes over and messes up a clean receiver signal.
Tidy up your cables and the boat should run fine.
What size prop do you run?
It looks a tad big.
Regards, Jan.
