RE: Cline regulator
i believe that on the exaust stroke it developes somewhere between 3 to 6 lbs depending on the engine.and especialy the rpms,more pressure higher rpms so theres no problem with the check valve keeping pressure in the tank. cause it does work! and then the regulator then only delivers what the demand is
