RE: Rookie's bad behavior info. needed
Mat,
Set the pipe level and you may need a very small amount of up in the elevons. It took a few flights before I found the best setup between the two. You may need to put a very small amount of down in the pipe if the plane climbs at high power settings. Set the CG right where they say it is perfect there. SLOW the plane down on final and it won't bounce.
