DA 50 vs. ZDZ 60
Ok guys, I'm getting a wild hare edge (28%) and I'm thinking about getting a ZDZ 60 for it. How would this engine compare to the DA 50? I know they're two different sizes, but the DA as we all know is an all out powerhouse. Both engines cost about the same and the real is difference is the ZDZ weighs a little bit more. Plus it will balance with a pull-pull set up since a 3W 50 weighs 4.4 lbs. and will balance with pull-pull. So the weight change would be minimal. Any idea of what prop to run?
