take a look at this, and test run it from the link on my prior post
Or set it up on a page and run it for yourself. you can modify the code and set it up as you like. Our room has been online for about 2 years now and is established.... the server its own is fairly reliable and rarely go's down. We have good, moderators (room ops) already in place. However if you still want to go out own you own... you can set this applet up to go to a room that you can founder. I would hope that you would atleast give us the oppertunity first. as stated in my prior post, this room is already set up for 2 other BB's and the user base is virtually the same people. Why not just join us?
If you do decide to go your own route, I would still be glad to help you set it up on the irc server or help in any way i can.
Southerngent
Copy the HTML below to add this Chat Room to your website...
<table border=0 width=500 align=center><tr><td>
<applet archive="http://backpack.webmaster.com/backpack/cr.zip"
codebase="http://backpack.webmaster.com/backpack/"
name=cr
code="ConferenceRoom.class"
width=550
height=450>
<param name=channel value=#rc_chat>
<param name=showbuttonpanel value=false>
<param name=bg value=EEEEEE>
<param name=fg value=000000>
<param name=roomswidth value=0>
<param name=lurk value=false>
<param name=simple value=false>
<param name=restricted value=false>
<param name=showjoins value=true>
<param name=showserverwindow value=true>
<param name=nicklock value=false>
<param name=playsounds value=true>
<param name=onlyshowchat value=false>
<param name=showcolorpanel value=false>
<param name=floatnewwindows value=false>
<param name=timestamp value=false>
<param name=listtime value=0>
<param name=guicolors1 value="youColor=000000;operColor=FF0000;voicecolor =006600;userscolor=000099">
<param name=guicolors2 value="inputcolor=FFFFFF;inputtextColor=000099;ses sioncolor=FFFFFF;systemcolor=0000FF">
<param name=guicolors3 value="titleColor=FFFFFF;titletextColor=000099;ses siontextColor=000000">
<param name=guicolors4 value="joinColor=009900;partColor=009900;talkcolor =000099">
<param name=nick value="Guest">
<center> This application requires Java suport.
This server also available via IRC at:
irc://IRC.WEBMASTER.COM:6667/</center>
</applet>
</td></tr></table>
