ORIGINAL: pompebled
Hi Green,
Can you post a few pics of the boat; side-, top-, and rear view?
Not at an angle, just full rear, full top, full side to see what the hullshape looks like.
How many cells does the motor run on now?
What size prop?
This is a large hull, what is it made of?
I see, ABS, hmmm, that means reinforcing before putting in a 700 motor
For this size hull a 700 motor on 12-14 cells would be a better solution, maybe a 800 on 18-20 cells would be even better.
Give us some more info, please.
Thanks for the pic's.
Is that a steering outdrive?
Does it work with an universal joint or a flexcable?
Regards, Jan.
