electric engine question
bought a 41 in boat off ebay , it had a purple light 550 motor in it the boat wont go fast enough to plane off. was wondering if someone could tell me what other motor i could use that would be better thanks
Hi Green,
Can you post a few pics of the boat; side-, top-, and rear view?
How many cells does the motor run on now?
What size prop?
This is a large hull, what is it made of?
For this size hull a 700 motor on 12-14 cells would be a better solution, maybe a 800 on 18-20 cells would be even better.
Give us some more info, please.
Regards, Jan.
What size prop?
Regards, Jan.
Hey jan here are a few pictures of the boat, it is pretty big for the 550. the hull is plastic do not know what size prop. no num bers or lettering on it. it has a 7.2 volt system in it Thanks much
ORIGINAL: pompebled
Hi Green,
Not at an angle, just full rear, full top, full side to see what the hullshape looks like.
What size prop?
I see, ABS, hmmm, that means reinforcing before putting in a 700 motor
Hi Green,
What size prop?
Is that a steering outdrive?
Does it work with an universal joint or a flexcable?
Regards, Jan.
That's what I thought, too bad.
If you decide to upgrade to a direct drive with a 700 motor and keep the steering outdrive (which allows for pretty accurate steering, no arguments there), you'll need to reinforce the hull and possibly the transom to keep the 700 motor from trashing your hull....
Also the bearing in the outdrive need to get replaced by ballbearings and an thrustbearing to keep the universal joint in one piece.
Make sure the steering outdrive is mechanically limited to about 15 degrees to each side, or you'll swim a lot, as the universal joint gets shredded by binding.
Otherwise, go for it!
This hull can handle a lot of speed.
Regards, Jan.
Regards, Jan.
Hey there again pompebled, really appreciate all the information you have shared with me . will try and use what you said, will get back to you as soon as i get it finished Thanks much
