RE: Using different wing now-need C of G Help!
Matt,You go by the wing for the CG,not the fuse,,,The CG for the Nextar wing should be around 2.625 from the leading edge.A good rule of thumb on these planes is that the CG is normally located on the main spar of the wing,give that a whirl.That is a high wing trainer,if you change something drastic you will have your hands full,but you are not, balance that plane on the main spar of the Nextar wing and you will be good to go.Happy Flying,,,,,,,,Slade
