RCU Forums - View Single Post - Cermark Banshee
Old 10-02-2004 | 03:59 PM
  #34
3dandpatternflyer's Avatar
3dandpatternflyer
Default RE: Cermark Banshee
I thought if I went from a 3:1 to a 4:1 gearing, that would make it easier on the motor, plus it would draw less amps. Does that mean it would produce less thrust/power with all else being equal?
Actually, if u make the gear ratio smaller and use the same prop, it harder on the motor if u went from a 4:1 to a 3:1. With a lower gear ration like that, u draw more amps. With the lower gear ratio, u'd probably produce more power using the same prop.
This is why a lot of people who fly 3D never use direct drive. Its all about swinging the biggest prop and getting the most thrust.
Correct me if im wrong Mr. Parsons
TTYL, Andrew T.
