RE: evader st is sluggish
May Have Jacked Your Throt Linkage Just A Tad !! (bent it some). Check The Linkage Spring Adj!! Or Evader 53 Has A Point Check The Ex Screws! And Check Any Other Basics That You Might Have Did When You Replaced The Clutch Spring !! Did It Do It Before Clutch Sping R&R?
