RC Nitro Stadium Trucks Discuss all aspects of rc nitro stadium trucks here
evader st is sluggish
Old 10-01-2004 | 04:58 PM
Default evader st is sluggish
my clutch spring was broken and I just fixed it and when I started the car up the first five tanks it ran great but after that when I would accelerate from idiling the bottom end had little acceleration and sounded super rich and I checked it and it was fine. No matter how rich or lean I tuned the bottom end it did the same thing every time. One thing I did notice is that as soon as I let off the gas the brake engages way more than it is supposed to. I did take the slipper apart and put it back and maybe I missaligned something on accident. My throttle servo seems to be working just fine and my slipper is tightened right. Someone please help.
Old 10-02-2004 | 03:19 PM
Evader 53's Avatar
Default RE: evader st is sluggish
I sort of had that same problem. What had happened was that the screws that hold on the exhaust had fallen out and i tried tuning it and nothing. If this ends up to be the problem you LHS should carry those screws.
Old 10-02-2004 | 11:02 PM
May Have Jacked Your Throt Linkage Just A Tad !! (bent it some). Check The Linkage Spring Adj!! Or Evader 53 Has A Point Check The Ex Screws! And Check Any Other Basics That You Might Have Did When You Replaced The Clutch Spring !! Did It Do It Before Clutch Sping R&R?
