RE: Q: Head Gasket Modification
There will be distortion at the edge, the sharper the scissors the less of course. Regardless, unless you crease the new gasket it will conform when the head is pulled down on it. Any spot bent up will have a point or line contact when you start pulling the head down, this will concentrate the pressure there, and flatten the gasket as though you were ironing a starched shirt.
Bill.
