Move the control rod clevis in a hole or two on the aileron control horn, that will add aileron throw. The manufacturers usually call for low throw to keep the plane docile until you want more. I'm sure the Stick would likely withstand full throw without too much difficulty. Just don't pull full aileron in a high speed dive, especially if you've also over powered the plane.
Dennis-
