RCU Forums - View Single Post - Servo Chatter
Old 10-05-2004 | 06:19 PM
50+AirYears
Default RE: Servo Chatter
Also, if the end of your transmitter antenna was pointed at the end of the plane's antenna end, you will have the worst possible signal pattern for range. Very little signal is emmitted from the end of the antenna, and the end of the reciever antenna is not it's most sensitive point. Think of the radiation pattern as being a doughnut with the antenna going straight up through the middle.
