RE: Crossing pull pull?
Here's another question. I was planning on using a SWB arm on the rudder pull-pull with ball links. I wanted to use SWB arms on the rest of the connections but what type of connector should I use on them since I don't want metal-metal contact or to put excessive twist on the rods which could break them? Did you use Du-Bro HD servo arms on elevator and ailerons?
