Stinger
Nits, The only pictures I have arn't from the proper view, however I will try and explain. The wing sits into the Fuselage and is pinned on in the front. The bulkhead where pins go into holds the Fuselage together, the sides break just behind this bulkhead below the wing leading edge. The sides will do the same thing at the bulkhead at the trailing edge of the wing. Triangle stock epoxied inside and carbon fiber strips outside top and bottom has worked well for me, do the carbon carefully with a little epoxy over the top and sand lightly until smooth , then cover. Worked for me, anyway.
