RCU Forums - View Single Post - BEST & NEW ARC F3A 2m IMPULSE
Old 10-10-2004 | 02:41 PM
uav-oscar
Default BEST & NEW ARC F3A 2m IMPULSE
Hi Pattern Fliers,
I want to share my feelings with you about my NEW 2m. F3A plane IMPULSE...
When I open the box ; its really hard to believe how beautiful & light and well built ARC plane it was... The biggest advantage of the plane is ; almost everything that you need in the box such as: Soft mount, carbon landing gear, ball bearing elevator bell crank with carbon pushrod, aluminium nose ring ( I request YS DZ size if you have OS RX just tell them!), wing & stab adjusters, aluminium axles for landing gear, carbon stab & wing tube, carbon spinner, pull-pull control system for rudder, tail wheel assembly, ultra light fiber wheel pants, hinges & all screws+nuts included the kit and you do not need to spend any more dime for all these accessories !!!
The other advantage of IMPULSE is: Carbon honey comb fire wall + all honeycomb formers and servo tray comes installed...carbon landing gear plate installed & drilled + wing & stab tubes and their adjuster mechanism installed... The fusalage fully composite with carbon fiberglass, Herex TAVS sandwich style and weight : 18 oz. hard to believe isn't it but really strong !!
The best thing of this plane is of course price : with all these accessories 899 $ usd
my IMPULSE configuration is:
YS 140 DZ with hatori tuned pipe + 16.5 x 12W apc prop+ JR 10x radio with futaba digital 9650 s on ailerons+ 9252 on elevator+ jr digital 8411 on rudder and hitec hs 85 micro on throttle control + 4.8 v 850 mah AAA battery ... flying weight 4.580 gram
Flying is extremely smooth & stable and vertical performance is superb !!! For P-05 programme this machine is perfect when I compare with my Hydeout ...The fuse is wide enough to dive sooo slow that you have much more time for everything..
As a result I found my new plane for 2005 France ...my new project will be to built another one for Plettenberg electric motor version and hope to fly in a 2 month ..
By the way if you interets on this ARC IMPULSE just check the web site: www.bnmodels.com
Happy landings
Oscar
