RE: BEST & NEW ARC F3A 2m IMPULSE
Hi all,
I also would like to share my personal thoughts about the ''Impulse''.
I saw the plane in the Turkish Nats about one month ago in Istanbul. First of all it is almost unbelivable to see the accesories coming with the kit. It is all in very high quality and includes everything that u can not see or I had never seen in a F3A kit before.
Because I believe that there are soo many rc fliers who can not afford to buy f3a plane with the all necessary accesories like Hyde-mount , carbon landings , carbon wing tube etc..These smalls things always blows up the total cost.But now I can afford to fly a pro in 4.6 kg's with the included accesories. It is unbeliveable again.
I had also had a chance to compare the kit with the Roland Matt's Smagrad-z (which was bought by my friend Ugur Bozduman) , and 2 new unfinished lazulite kits. When you compare the fusalage of the two kits it is so clear to see the strength of the Impulse because of the vacuum bagging and Herex.The lazulite is also very light and clear but I think you have only one chance to land in a bad way with the stiffness of its carbon-kevlar fuselage. Because I belive there could always be an emergancy landings. The impulse's fusalage has like a shock absorbing effect and it has a very compact total strength.
So I immediately ordered 2 İmpulse kits from Bnmodels.
I recommend you to check the price and order yours immediately.
