RE: Precision Eagle 4.2 Performance Question
Will likely run with the smaller diameter prop, too, once I understand why its not performing to spec. I've got most of the problem solved - would like to finish it. I expect that there is a trade off between speed, rate of climb and acceleration when switching between prop diameters. If the 24x10 is overloading the engine, then perhaps all three measures would improve with a smaller prop.
DaleCS
