RE: E-Flight Tribute
How much do you have? Should have around 45 degrees.
Are you putting the rods into the outer holes of the servo arms and into the inner holes of the control horns? This will give max throw. If you still don't have enough all you can do is use new longer servo arms or find a way to make them longer.
