RCU Forums - View Single Post - Fuel Line Setup on Magic Extra OS 46
Old 10-12-2004 | 12:31 PM
JoeAirPort's Avatar
JoeAirPort
My Feedback: (41)
Default RE: Fuel Line Setup on Magic Extra OS 46
ORIGINAL: Bruno Stachel
I have the 46 FX on mine. My memory is a little sketchy, but I recall using some needle nose pliers to slip the fuel line on. After that, I left it there, because I also ran a third line to the fuel tank for fueling. I installed just enough line to be able to grab it and remove a Dubro fuel line plug for fueling. The third fueling line just dangle out the top behind the engine. A fuel dot, fastened to one of the cheeks, would probably be a neater more reliable method though. But that engine takes up a lot of space. There are fueler valves also, that connect in line with the fuel line (tank to carb).
The 2nd clunk and fuel dot on the cheek is a good idea. Remember that pulling on the fuel line with a needle nose is going to tear up the line sooner or later.
