RCU Forums - View Single Post - Fuel Line Setup on Magic Extra OS 46
Old 10-13-2004 | 02:39 PM
LJR
My Feedback: (8)
Default RE: Fuel Line Setup on Magic Extra OS 46
I have the same set -up mentioned above , ie. a third line capped off with a fuel dot. Works fine.
The only smallish problem is de-fueling the plane at the end of the day. Unless you put that line in towards the front of the tank and below the stopper & then tilt the plane forward to defuel - you'll never get all the fuel out.
