RE: Engine Issues and Gaskets
Diffrent size sims will give u diffrent amounts of commpression. For instance, a thinner sim will give you more compression, becasue you decreas the head clearance. An a thicker sim will increase the head clearance, wich will reduce the compression. Dont go to thin tho becasue you can blow up you motor. Check you manual for limitations.
