Engine Issues and Gaskets
If an engine does not have an engine shim or a rear plate gasket, will this lead to reduced compression? Simply, I purchased an engine off of ebay and these parts were not included once received. My initial thought was to purchase a new piston and sleeve, however, I took the engine apart and noticed the missing parts. Any information would be appreciated.
Thanks.
Thanks.
NS, CANADA
You have to have a head shim, as for the backplate gasket not being there that would cause a major leak as well as compression loss, you can use clear silicon to seal up the backplate or see if you can buy a real gasket, i would hold off on the rebuild till you get the other problems fixed and test the engine.
.26 maxx
savage ss
nitro evader
ntc3
gtx xxt
.26 maxx
savage ss
nitro evader
ntc3
gtx xxt
NY
Diffrent size sims will give u diffrent amounts of commpression. For instance, a thinner sim will give you more compression, becasue you decreas the head clearance. An a thicker sim will increase the head clearance, wich will reduce the compression. Dont go to thin tho becasue you can blow up you motor. Check you manual for limitations.
