RCU Forums - View Single Post - VMAR Easy 3D
Thread: VMAR Easy 3D
Old 10-18-2004 | 06:26 PM
max42's Avatar
max42
Default RE: VMAR Easy 3D
I bought one of the new VMAR Easy 3Ds and had my maiden flight today. I was impressed with the construction and covering, especially since VMAR has not had the best reputation in the past. I used a OS46FX in it. The plane showed no bad tendencies during flight, slowed to a crawl, no tip stall. It's a light plane so it will get bounced around if there is much turbulence.
The instructions were very good. The fuselage is narrow which does not leave much options for securing the battery and receiver. I stacked the battery and receiver directly behind the tank. If I had to complain about something it would be that the wing does not snug up tightly to the fuse. I added a lock washer to the nut that secures the wing to the fuse and didn't see any issues with holding the wing. A snug fit would "look" better. I mounted the switch on the access hatch on the bottom, but I'm not crazy about that location, just no room on the side of the fuse.
I didn't try any 3D stuff, just two quick flights before it got too dark. A nice flying plane. :-)
