RCU Forums - View Single Post - Quick build "Composite" e-Taco
Old 10-18-2004 | 09:57 PM
sledge4055
Default RE: Quick build "Composite" e-Taco
i notice your useing a poly quest 2600 pack what charger are you useing to charge the reason im asking is cause i just recieved my poly quest pack and after running it it will only charge to 1997 mah im wondering if im do ing some thing wrong or what .. ive got a triton charger it will only charge at 2.5 amps max i have it set for 11.1v 2.5amps charge ive discarged it down to 9v and recharged it back to peak and still its only reading 1997mah at peak im not sure if its the pack or if the charger could be give ing me a false peak any ideas?
